Speaker / cabinet Vibration
I think I know what you are describing.
I would say check your decoupling caps but you said you have replaced them.
Output Tubes?
Also: have you checked that your output transformer is good all the way? From the centertap to each end? Are teh voltages on both tubes anodes (plates) correct?
Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 02:39 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 07:39 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 08:55 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 09:13 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 09:35 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 10:18 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 11:29 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 11:30 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 11:33 PM
RE: Speaker / cabinet Vibration - by 7estatdef - 05-12-2013, 08:04 AM
RE: Speaker / cabinet Vibration - by codefox1 - 05-13-2013, 10:41 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
