Speaker / cabinet Vibration
And the last thing (not likely but) - the speaker itself. Just for giggles if you have a similar speaker, you might connnect it and see if the same thing is happening.
First if the speaker has the transformer attached you will be eliminating both at the same time, and then if it shows improvement, you can then try to see which one of the two is the culprit.
Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 02:39 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 07:39 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 08:55 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 09:13 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 09:35 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 10:18 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 11:29 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 11:30 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 11:33 PM
RE: Speaker / cabinet Vibration - by 7estatdef - 05-12-2013, 08:04 AM
RE: Speaker / cabinet Vibration - by codefox1 - 05-13-2013, 10:41 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
