Speaker / cabinet Vibration
I had a similar vibration problem on my 48-1253. By mid volume, the vibration was very noticeable. It turned out there were some teeny tiny little round moth holes in the speaker cone. Once I sealed those up with liquid tape, the vibration stopped. Not saying that's the case with Ronin61's set, though.
Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 02:39 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 07:39 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 08:55 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 09:13 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 09:35 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 10:18 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 11:29 PM
RE: Speaker / cabinet Vibration - by Ronin61 - 05-11-2013, 11:30 PM
RE: Speaker / cabinet Vibration - by morzh - 05-11-2013, 11:33 PM
RE: Speaker / cabinet Vibration - by NostalgiaRadioTime - 05-12-2013, 01:32 AM
RE: Speaker / cabinet Vibration - by 7estatdef - 05-12-2013, 08:04 AM
RE: Speaker / cabinet Vibration - by codefox1 - 05-13-2013, 10:41 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
