Philco 37-630 nameplate
OK thanks Ron here is a question you might be able to answer there is a paper tag still on the inside of the cabinet ===part no.102561====final insp. no. 122031 and run no. which I cant make out. What do the numbers mean? I bought the radio up in Frankenmuth Michigan at a antique shop for $20 dollars. Thanks again Ron.
Philco 37-630 nameplate - by marilynmonroe - 05-11-2013, 08:23 PM
RE: Philco 37-630 nameplate - by Ron Ramirez - 05-11-2013, 08:26 PM
RE: Philco 37-630 nameplate - by marilynmonroe - 05-12-2013, 10:15 AM
RE: Philco 37-630 nameplate - by marilynmonroe - 05-12-2013, 10:33 AM
RE: Philco 37-630 nameplate - by Ron Ramirez - 05-13-2013, 01:27 PM
