Another Philco oddity?
I have a 90 cabinet, and the rubber date stamp on the bottom is:
OCT6-'4
I know they didnt make 90's after 1932... so whats up with this?
am I reading it wrong? its a very clear stamp.
Thanks
Keith
Another Philco oddity? - by Keith Park - 12-27-2007, 09:33 PM
[No subject] - by Ron Ramirez - 12-29-2007, 11:01 PM
[No subject] - by Keith Park - 12-30-2007, 10:26 PM
Philco 91 Tuning Condenser
