  • 2 Vote(s) - 5 Average
Philco model 18 (code 121) - HELP!
Jerry, here are the results
EXPECTED RESULTS ARE FIRST, AND MY RESULTS ARE INSIDE THE [BRACKETS]
...................................78-I.F...............6A7-Det._Osc............78-R.F...............75-2nd Det
Filament Volts F to F:............6.3 [5.9]................6.3 [5.9]...........6.3 [5.9].............6.3 [5.9]
Plate Volts P to K:...............210 [272]................210 [246]...........210 [272].............120 [192]
Screen Grid Volts SG to K:........80 [85.3]................80 [88.7]...........80 [88.7].............N/A [N/A]
Control Grid Volts CG to K:.......0.3 [0.0]..............0.15 [3.18]...........5.3 [0.0]............0.3 [1.42]
Cathode Volts K to F:.............2.8 [9.3]................2.8 [5.9]............5.3 [12]...............0 [2.8]
G1 to K:..........................N/A [N/A]................35 [12.4]
G2 to K:..........................N/A [N/A]..............130 [109.7]
.................................42-2nd A.F.........42-Output..........42-Output............80-Tube
Filament Volts F to F:............6.3 [5.9]..........6.3 [6.0]..........6.3 [6.0]...........5.0 [ 4.7]
Plate Volts P to K:...............205 [258]..........280 [292]..........280 [272]............350 [365]
Screen Grid Volts SG to K:........200 [257]..........300 [292]..........300 [272]
Control Grid Volts CG to K:.......0.35 [15]............28 [27]............28 [27]
Cathode Volts K to F:...............0 [0.0]............0 [0.0]............0 [0.0]
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-07-2013, 10:22 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-08-2013, 10:32 PM
RE: Philco model 18 (code 121) - HELP! - by Arran - 02-08-2013, 10:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 02:21 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 05:57 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 06:12 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-13-2013, 08:40 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-21-2013, 05:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-28-2013, 06:04 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 04:16 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 11:20 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-17-2013, 01:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 09:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-29-2013, 10:02 PM
RE: Philco model 18 (code 121) - HELP! - by Pithicus999 - 05-13-2013, 07:51 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-12-2013, 01:37 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-13-2013, 08:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-23-2013, 10:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-24-2013, 11:11 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-02-2013, 05:06 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-21-2013, 10:26 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-17-2013, 10:58 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 12:47 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 01-17-2014, 04:05 PM
Users browsing this thread: 40 Guest(s)
Philco 91 Tuning Condenser
