116x Restoration
Brenda,
What were you looking at when you came up with the 950ma figure? I've been trying to figure out how to determine how many amps/ma's the set should be pulling.
-Keith
116x Restoration - by ipwizard - 04-04-2013, 01:53 AM
RE: 116x Restoration - by morzh - 04-04-2013, 11:43 AM
RE: 116x Restoration - by ipwizard - 04-05-2013, 12:21 AM
RE: 116x Restoration - by morzh - 04-05-2013, 03:11 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 03:55 PM
RE: 116x Restoration - by ipwizard - 04-05-2013, 05:30 PM
RE: 116x Restoration - by Ron Ramirez - 04-05-2013, 09:18 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 11:08 PM
RE: 116x Restoration - by codefox1 - 04-06-2013, 08:24 AM
RE: 116x Restoration - by ipwizard - 04-06-2013, 12:58 PM
RE: 116x Restoration - by ipwizard - 04-09-2013, 11:44 AM
RE: 116x Restoration - by ipwizard - 04-15-2013, 05:25 PM
RE: 116x Restoration - by Mondial - 04-15-2013, 09:04 PM
RE: 116x Restoration - by 7estatdef - 04-15-2013, 09:40 PM
RE: 116x Restoration - by ipwizard - 04-16-2013, 02:37 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 12:48 AM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 01:10 AM
RE: 116x Restoration - by 7estatdef - 05-14-2013, 06:51 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 11:16 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 01:03 PM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 03:49 PM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 PM
RE: 116x Restoration - by Mondial - 05-14-2013, 10:26 PM
RE: 116x Restoration - by ipwizard - 05-15-2013, 06:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
