116x Restoration
I looked at the current ratings on the secondary windings on the Rider's schematic, and did the math approximation from those with necessary multiplication and division to bring them to the 110 volt line voltage. It's only the barest approximation in this case, though, because I did not figure in transformer losses and didn't use precise measurements, only ballpark estimates.
116x Restoration - by ipwizard - 04-04-2013, 01:53 AM
RE: 116x Restoration - by morzh - 04-04-2013, 11:43 AM
RE: 116x Restoration - by ipwizard - 04-05-2013, 12:21 AM
RE: 116x Restoration - by morzh - 04-05-2013, 03:11 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 03:55 PM
RE: 116x Restoration - by ipwizard - 04-05-2013, 05:30 PM
RE: 116x Restoration - by Ron Ramirez - 04-05-2013, 09:18 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 11:08 PM
RE: 116x Restoration - by codefox1 - 04-06-2013, 08:24 AM
RE: 116x Restoration - by ipwizard - 04-06-2013, 12:58 PM
RE: 116x Restoration - by ipwizard - 04-09-2013, 11:44 AM
RE: 116x Restoration - by ipwizard - 04-15-2013, 05:25 PM
RE: 116x Restoration - by Mondial - 04-15-2013, 09:04 PM
RE: 116x Restoration - by 7estatdef - 04-15-2013, 09:40 PM
RE: 116x Restoration - by ipwizard - 04-16-2013, 02:37 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 12:48 AM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 01:10 AM
RE: 116x Restoration - by 7estatdef - 05-14-2013, 06:51 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 11:16 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 01:03 PM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 03:49 PM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 PM
RE: 116x Restoration - by Mondial - 05-14-2013, 10:26 PM
RE: 116x Restoration - by ipwizard - 05-15-2013, 06:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4031 online users. [Complete List]
» 1 Member(s) | 4030 Guest(s)
