5Y3 question
Hi,
I thought some of those SS replacements available had other components inside to give a 'soft-start- just as a tube would?
( http://www.webervst.com/ccap.html)
Yes, replacing the 5Y3 with just a couple of diodes you'd get more B+ and you'd have to adjust that,(again, heat dissapation from a resistor) and you still have the instant B+ which a standard tube does not give right away.
Personally, I'd leave the tube in as designed.
As far as your fan, that's up to you. I would have the fan pulling the warm air out, instead of blowing on the tubes. Pulling the ai out might give a better overall airflow to the whole chassis. Remember though, you have to have a source of incoming air.
5Y3 question - by shaler78 - 05-07-2013, 10:35 PM
RE: 5Y3 question - by BrendaAnnD - 05-07-2013, 10:52 PM
RE: 5Y3 question - by morzh - 05-07-2013, 10:52 PM
RE: 5Y3 question - by Mondial - 05-07-2013, 10:57 PM
RE: 5Y3 question - by shaler78 - 05-07-2013, 11:33 PM
RE: 5Y3 question - by gary rabbitt - 05-14-2013, 08:30 PM
RE: 5Y3 question - by codefox1 - 05-16-2013, 01:31 PM
RE: 5Y3 question - by morzh - 05-16-2013, 02:09 PM
RE: 5Y3 question - by shaler78 - 05-16-2013, 07:40 PM
RE: 5Y3 question - by gary rabbitt - 05-17-2013, 12:00 AM
RE: 5Y3 question - by shaler78 - 05-17-2013, 12:14 AM
RE: 5Y3 question - by BrendaAnnD - 05-17-2013, 12:29 AM
RE: 5Y3 question - by Arran - 05-17-2013, 01:11 AM
RE: 5Y3 question - by BrendaAnnD - 05-17-2013, 02:25 AM
RE: 5Y3 question - by Marsupial - 05-17-2013, 10:13 AM
RE: 5Y3 question - by codefox1 - 05-17-2013, 01:15 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
