Where to find new drive belts?
Mike, I know you have the schematic for the radio, but here is the link to the manual for the phono itself. It would be good to have on hand if servce is needed in the future.
http://antiqueradios.com/gallery/main.ph...3ca646782f
Right click on the link , and select Save Target As...to save. You will need to use the Djvu reader to open the file. Other diagrams such as the ones from Beitman are opened with the djvu reader. You can get it here:
http://djvu.org/resources/
Where to find new drive belts? - by ODPILOT - 05-08-2013, 04:36 PM
RE: Where to find new drive belts? - by ODPILOT - 05-10-2013, 09:09 PM
RE: Where to find new drive belts? - by gary rabbitt - 05-15-2013, 09:49 PM
RE: Where to find new drive belts? - by ODPILOT - 05-16-2013, 07:30 AM
RE: Where to find new drive belts? - by ODPILOT - 05-18-2013, 11:22 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
