Philco Model 20
Schematic and other info here: http://www.nostalgiaair.org/PagesByModel...029582.pdf
It is recommended that you change out all the electrolytic and paper capacitors, and it is easy and cheap enough to replace the carbon resistors (many of which will have drifted way up or become otherwise tempermental) at the same time before powering the set up again. Any rotted out or ratty wires including the line cord should also be replaced as well.
Then let's see what you have.
Philco Model 20 - by pete7189 - 05-16-2013, 12:34 AM
RE: Philco Model 20 - by codefox1 - 05-16-2013, 01:13 PM
RE: Philco Model 20 - by GarySP - 05-16-2013, 06:39 PM
RE: Philco Model 20 - by Arran - 05-16-2013, 07:26 PM
RE: Philco Model 20 - by GarySP - 05-16-2013, 09:58 PM
RE: Philco Model 20 - by gary rabbitt - 05-16-2013, 11:34 PM
RE: Philco Model 20 - by Arran - 05-17-2013, 03:03 AM
RE: Philco Model 20 - by pete7189 - 05-17-2013, 07:20 AM
RE: Philco Model 20 - by Mondial - 05-17-2013, 02:15 PM
RE: Philco Model 20 - by pete7189 - 05-19-2013, 11:55 PM
RE: Philco Model 20 - by Arran - 05-20-2013, 01:00 AM
RE: Philco Model 20 - by pete7189 - 05-20-2013, 03:07 AM
RE: Philco Model 20 - by GarySP - 05-20-2013, 11:03 AM
RE: Philco Model 20 - by pete7189 - 05-24-2013, 02:57 AM
RE: Philco Model 20 - by 7estatdef - 05-26-2013, 08:05 AM
RE: Philco Model 20 - by Phlogiston - 05-26-2013, 09:48 AM
RE: Philco Model 20 - by pete7189 - 05-26-2013, 06:52 PM
RE: Philco Model 20 - by Phlogiston - 05-26-2013, 07:40 PM
RE: Philco Model 20 - by morzh - 05-26-2013, 08:05 PM
RE: Philco Model 20 - by pete7189 - 05-27-2013, 01:11 AM
RE: Philco Model 20 - by Phlogiston - 05-27-2013, 09:34 AM
RE: Philco Model 20 - by morzh - 05-27-2013, 11:24 AM
RE: Philco Model 20 - by GarySP - 05-27-2013, 07:24 PM
RE: Philco Model 20 - by morzh - 05-27-2013, 08:01 PM
RE: Philco Model 20 - by pete7189 - 05-28-2013, 06:27 AM
RE: Philco Model 20 - by 7estatdef - 05-28-2013, 07:25 AM
RE: Philco Model 20 - by klondike98 - 05-28-2013, 09:30 AM
RE: Philco Model 20 - by morzh - 05-28-2013, 11:08 AM
RE: Philco Model 20 - by klondike98 - 05-28-2013, 02:09 PM
RE: Philco Model 20 - by pete7189 - 06-01-2013, 02:06 AM
RE: Philco Model 20 - by morzh - 06-01-2013, 11:35 AM
RE: Philco Model 20 - by GarySP - 06-02-2013, 04:22 PM
RE: Philco Model 20 - by pete7189 - 06-04-2013, 10:43 PM
RE: Philco Model 20 - by morzh - 06-04-2013, 10:46 PM
RE: Philco Model 20 - by pete7189 - 06-05-2013, 12:08 AM
RE: Philco Model 20 - by GarySP - 06-05-2013, 12:34 PM
RE: Philco Model 20 - by pete7189 - 06-06-2013, 04:25 AM
RE: Philco Model 20 - by GarySP - 06-06-2013, 12:24 PM
RE: Philco Model 20 - by pete7189 - 06-26-2013, 10:53 PM
RE: Philco Model 20 - by morzh - 06-26-2013, 11:11 PM
RE: Philco Model 20 - by pete7189 - 06-26-2013, 11:18 PM
RE: Philco Model 20 - by morzh - 06-27-2013, 01:36 PM
RE: Philco Model 20 - by pete7591 - 09-12-2014, 02:07 AM
RE: Philco Model 20 - by morzh - 09-12-2014, 10:15 AM
RE: Philco Model 20 - by radiohenry - 09-12-2014, 03:53 PM
Users browsing this thread: 18 Guest(s)
There are currently 10328 online users. [Complete List]
» 3 Member(s) | 10325 Guest(s)
