philco 50-1718 help
Like I said in your other message, here on the Phorum, 3.2 ohms is the original speaker. A 4 ohm unit will match ok too.
philco 50-1718 help - by Guest - 12-29-2007, 02:18 AM
[No subject] - by Chuck Schwark - 12-29-2007, 11:42 AM
Philco 91 Tuning Condenser
