Can't leave well enough alone-48-482
Hold off on adjusting the FM detector (C300b & TC300) for now. Just get the IF chain lined up well.
RE: Can't leave well enough alone-48-482 - by mgutierres - 05-16-2013, 04:47 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
