Can't leave well enough alone-48-482
Okay, back to my first point. Did you test the continuity of C403?
RE: Can't leave well enough alone-48-482 - by mgutierres - 05-16-2013, 08:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
