Push on/off switch
Does anyone know of a good alternative replacement for the push on/off power switch for table models like 41-245. My current project had had it conveniently bypassed with a lovely toggle switch prior to me, and the 'guts' of the original switch are missing - the PB and rod are still in the push button rack but not connected to / containing anything. I'd like to restore this model to its original state, but I haven't found any replacements. Any suggestions?
Push on/off switch - by Guest - 12-29-2007, 03:38 PM
[No subject] - by Ron Ramirez - 12-29-2007, 11:11 PM
[No subject] - by Guest - 12-29-2007, 11:14 PM
There are currently 5953 online users. [Complete List]
» 1 Member(s) | 5952 Guest(s)
