Telechron Clock on a 51-537
Howdy:
I have a Philco 51-537 clock radio with a Telechron movement. It keeps time good.
Can someone explain how to set this alarm? Does this have a buzzer or does just it turn on the radio as a alarm?
Please explain the " Auto" function on the Auto/Off/On switch.
Also what is the Delay/Off for and is it used when setting the alarm.
I have been playing with this and unable to figure it out. Icon_crazy The "Auto" switch works the same as the "On" button as it switches on the radio. The Delay thingy just complicates the matter.. Maybe the dam thing just dosent work.
Thanks, Buzz
Telechron Clock on a 51-537 - by Buzz - 05-16-2013, 09:46 PM
RE: Telechron Clock on a 51-537 - by BrendaAnnD - 05-16-2013, 10:44 PM
RE: Telechron Clock on a 51-537 - by gary rabbitt - 05-17-2013, 12:03 AM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3545 online users. [Complete List]
» 1 Member(s) | 3544 Guest(s)
