5Y3 question
Hi, the 5Y3 will run hot , just by the nature of it. Same as an incandescent bulb, that's about right. If you have red glowing plates though, you may have other troubles Icon_eek
I have not made any readings, but some of the mini tubes like the 35W4 and 50C5, to me at least, seem to run hotter.
The insulation doesn't have to be too thick, the idea is to dissapate the heat over a wider area, compared to just above the tube.
5Y3 question - by shaler78 - 05-07-2013, 10:35 PM
RE: 5Y3 question - by BrendaAnnD - 05-07-2013, 10:52 PM
RE: 5Y3 question - by morzh - 05-07-2013, 10:52 PM
RE: 5Y3 question - by Mondial - 05-07-2013, 10:57 PM
RE: 5Y3 question - by shaler78 - 05-07-2013, 11:33 PM
RE: 5Y3 question - by gary rabbitt - 05-14-2013, 08:30 PM
RE: 5Y3 question - by codefox1 - 05-16-2013, 01:31 PM
RE: 5Y3 question - by morzh - 05-16-2013, 02:09 PM
RE: 5Y3 question - by shaler78 - 05-16-2013, 07:40 PM
RE: 5Y3 question - by gary rabbitt - 05-17-2013, 12:00 AM
RE: 5Y3 question - by shaler78 - 05-17-2013, 12:14 AM
RE: 5Y3 question - by BrendaAnnD - 05-17-2013, 12:29 AM
RE: 5Y3 question - by Arran - 05-17-2013, 01:11 AM
RE: 5Y3 question - by BrendaAnnD - 05-17-2013, 02:25 AM
RE: 5Y3 question - by Marsupial - 05-17-2013, 10:13 AM
RE: 5Y3 question - by codefox1 - 05-17-2013, 01:15 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3638 online users. [Complete List]
» 1 Member(s) | 3637 Guest(s)
