Philco Flexible Resistor wattage rating
http://www.philcorepairbench.com/flexrest.htm
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
[No subject] - by BDM - 12-29-2007, 06:52 PM
Philco 91 Tuning Condenser
There are currently 10247 online users. [Complete List]
» 1 Member(s) | 10246 Guest(s)
