Philco 60MB cabinet restoration
The clear coat is just fine Icon_smile I just finished up with the brown mahogany toner and it's just a bit more red than I'd like. Perhaps perfect brown would have been a better choice ? Regardless, I'll press forward and start masking it off for the black trim. I expect that's going to take quite a while!
[Image: http://farm8.staticflickr.com/7308/87471...b88c_c.jpg]
Philco 60MB cabinet restoration - by Bob Andersen - 04-06-2013, 06:57 PM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 07:46 AM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 04:26 PM
RE: Philco 60MB cabinet restoration - by Art Hoch - 04-07-2013, 05:40 PM
RE: Philco 60MB cabinet restoration - by Geoff - 04-08-2013, 11:57 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-09-2013, 10:38 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-21-2013, 11:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-04-2013, 12:48 AM
RE: Philco 60MB cabinet restoration - by Arran - 05-09-2013, 06:45 PM
RE: Philco 60MB cabinet restoration - by Bob Andersen - 05-17-2013, 01:33 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-17-2013, 08:20 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-18-2013, 08:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-20-2013, 11:54 PM
RE: Philco 60MB cabinet restoration - by jph14 - 05-22-2013, 04:46 PM
RE: Philco 60MB cabinet restoration - by EricS - 08-24-2013, 09:22 PM
There are currently 10557 online users. [Complete List]
» 2 Member(s) | 10555 Guest(s)
