Decals - So Called
Well, I forgot to mention spraying clear lacquer over the decals once they are dry and once the Micro Sol is dry, because I thought it was common knowledge that you don't want to leave decals bare - they need a clear coat or two of lacquer for protection.
Decals - So Called - by jmac3ky - 05-17-2013, 09:56 AM
RE: Decals - So Called - by Steve Davis - 05-18-2013, 10:54 PM
