Zenith...over rated or not!
Very well put Ron I have only one Zenith, I have had some in the past but did not think they performed as well as A Philco. Zenith never did have a radio that sounded as good as the ole 16B. That's my story and I am sicking to it. LOL Icon_thumbup
Joe
Zenith...over rated or not! - by 462ron - 05-18-2013, 09:59 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-18-2013, 10:10 PM
RE: Zenith...over rated or not! - by 462ron - 05-18-2013, 10:32 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-18-2013, 10:49 PM
RE: Zenith...over rated or not! - by w4rtc - 05-18-2013, 10:55 PM
RE: Zenith...over rated or not! - by Arran - 05-18-2013, 10:57 PM
RE: Zenith...over rated or not! - by BrendaAnnD - 05-19-2013, 02:00 AM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-19-2013, 08:45 AM
RE: Zenith...over rated or not! - by w4rtc - 05-19-2013, 04:08 PM
RE: Zenith...over rated or not! - by GarySP - 05-19-2013, 04:22 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-19-2013, 04:28 PM
RE: Zenith...over rated or not! - by TA Forbes - 05-19-2013, 04:32 PM
RE: Zenith...over rated or not! - by morzh - 05-19-2013, 04:41 PM
RE: Zenith...over rated or not! - by codefox1 - 05-19-2013, 05:03 PM
RE: Zenith...over rated or not! - by Eliot Ness - 05-19-2013, 10:09 PM
RE: Zenith...over rated or not! - by Arran - 05-19-2013, 11:51 PM
RE: Zenith...over rated or not! - by BrendaAnnD - 05-20-2013, 01:48 AM
RE: Zenith...over rated or not! - by morzh - 05-20-2013, 09:31 AM
RE: Zenith...over rated or not! - by Jayce - 05-20-2013, 03:49 PM
RE: Zenith...over rated or not! - by TA Forbes - 05-20-2013, 08:23 PM
RE: Zenith...over rated or not! - by Arran - 05-21-2013, 10:51 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-22-2013, 07:36 AM
RE: Zenith...over rated or not! - by murf - 05-24-2013, 12:06 PM
RE: Zenith...over rated or not! - by GarySP - 05-25-2013, 09:13 PM
RE: Zenith...over rated or not! - by murf - 05-25-2013, 09:56 PM
RE: Zenith...over rated or not! - by jcr1972 - 06-01-2013, 03:55 AM
RE: Zenith...over rated or not! - by TA Forbes - 06-01-2013, 11:01 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 06-01-2013, 11:15 PM
RE: Zenith...over rated or not! - by w4rtc - 06-01-2013, 11:56 PM
RE: Zenith...over rated or not! - by Eliot Ness - 06-02-2013, 01:36 PM
RE: Zenith...over rated or not! - by Art Hoch - 06-03-2013, 11:15 PM
RE: Zenith...over rated or not! - by rocketeer - 06-04-2013, 11:13 PM
There are currently 7935 online users. [Complete List]
» 2 Member(s) | 7933 Guest(s)
