My Zenith 8-S-661
I found this radio at a church rummage sale a couple weeks back for $50, which is cheap for a Zenith in good shape. Had it gone through and it is a good performer with the push-pull 6F6 tubes and really sucks in he stations. Icon_smile I also like the clean lines of the cabinet.
My Zenith 8-S-661 - by Jayce - 05-20-2013, 08:15 PM
RE: My Zenith 8-S-661 - by TA Forbes - 05-20-2013, 08:45 PM
RE: My Zenith 8-S-661 - by morzh - 05-20-2013, 09:51 PM
RE: My Zenith 8-S-661 - by NostalgiaRadioTime - 05-20-2013, 10:00 PM
