Zenith...over rated or not!
Since you brought it up, the 12S568/69 and 12S595 are very good sounding sets. They often fall under the "ignored" Z's.
However, they also fall under the "padding the tube count" type of Z's that I mentioned previously. Two 6X5s, two 6J5s serving as oscillator and 2d detector, and three 6J5s driving/inverting the PP6V6s. Also, there is only ONE I.F. amp.
In my opinion this design sacrifices ability to pull in distant stations, which is something I would think the buyer of an expensive high-tube count set would want.
Zenith...over rated or not! - by 462ron - 05-18-2013, 09:59 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-18-2013, 10:10 PM
RE: Zenith...over rated or not! - by 462ron - 05-18-2013, 10:32 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-18-2013, 10:49 PM
RE: Zenith...over rated or not! - by w4rtc - 05-18-2013, 10:55 PM
RE: Zenith...over rated or not! - by Arran - 05-18-2013, 10:57 PM
RE: Zenith...over rated or not! - by BrendaAnnD - 05-19-2013, 02:00 AM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-19-2013, 08:45 AM
RE: Zenith...over rated or not! - by w4rtc - 05-19-2013, 04:08 PM
RE: Zenith...over rated or not! - by GarySP - 05-19-2013, 04:22 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-19-2013, 04:28 PM
RE: Zenith...over rated or not! - by TA Forbes - 05-19-2013, 04:32 PM
RE: Zenith...over rated or not! - by morzh - 05-19-2013, 04:41 PM
RE: Zenith...over rated or not! - by codefox1 - 05-19-2013, 05:03 PM
RE: Zenith...over rated or not! - by Eliot Ness - 05-19-2013, 10:09 PM
RE: Zenith...over rated or not! - by Arran - 05-19-2013, 11:51 PM
RE: Zenith...over rated or not! - by BrendaAnnD - 05-20-2013, 01:48 AM
RE: Zenith...over rated or not! - by morzh - 05-20-2013, 09:31 AM
RE: Zenith...over rated or not! - by Jayce - 05-20-2013, 03:49 PM
RE: Zenith...over rated or not! - by TA Forbes - 05-20-2013, 08:23 PM
RE: Zenith...over rated or not! - by Arran - 05-21-2013, 10:51 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-22-2013, 07:36 AM
RE: Zenith...over rated or not! - by murf - 05-24-2013, 12:06 PM
RE: Zenith...over rated or not! - by GarySP - 05-25-2013, 09:13 PM
RE: Zenith...over rated or not! - by murf - 05-25-2013, 09:56 PM
RE: Zenith...over rated or not! - by jcr1972 - 06-01-2013, 03:55 AM
RE: Zenith...over rated or not! - by TA Forbes - 06-01-2013, 11:01 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 06-01-2013, 11:15 PM
RE: Zenith...over rated or not! - by w4rtc - 06-01-2013, 11:56 PM
RE: Zenith...over rated or not! - by Eliot Ness - 06-02-2013, 01:36 PM
RE: Zenith...over rated or not! - by Art Hoch - 06-03-2013, 11:15 PM
RE: Zenith...over rated or not! - by rocketeer - 06-04-2013, 11:13 PM
There are currently 7190 online users. [Complete List]
» 1 Member(s) | 7189 Guest(s)
