Model 70 refinish
Hi
You want to prepare the surface first by using grain filler over the entire surface of the radio cabinet. Some refinishers prefer to compensate for the pores in the grain by using several coats of lacquer instead of filler, rubbing down between every so many coats.
Grain filler can be tricky to use. You have to work fast...allowing the paste to se up just enough to remain in place without getting so hard that it is hard to remove the excess without sanding. Burlap material is handy for removing excess wood filler from the surface.
Once the surface is prepared and smooth, you apply toning lacquer until you have the correct uniform color overall, then apply clear lacquer OVER the toner, not vice-versa.
Stains can be used if the bare wood is blotchy and non-uniform; but the toners is what gives the cabinet its rick, uniform color overall.
I will readily admit that I am no expert on refinishing; I do much better at chassis work. But what I have given you here are the basics.
Model 70 refinish - by Guest - 12-27-2007, 05:19 PM
[No subject] - by Ron Ramirez - 12-31-2007, 01:24 AM
Toner question - by Guest - 12-31-2007, 12:25 PM
Eico 232 VTVM Schematic
