Looking for a Clean Schematic for 37-675
Why would they print it in Arabic OR sabotage it? The only people I know of in this country that speak Arabic are either tourists or embassy staff in Seoul.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
