1931 Escutcheons ?
Hi Drew
No, the Model 111's escutcheon only has the PHILCO trademark on it - no other words. The "SUPER HETERODYNE ELEVEN" wording was added to the escutcheon when Model 112 was introduced. And, yes, Model 111 is also a superheterodyne - in fact, the 111 was Philco's first superhet model.
1931 Escutcheons ? - by Drew - 01-02-2008, 09:44 PM
[No subject] - by Ron Ramirez - 01-02-2008, 11:32 PM
There are currently 7523 online users. [Complete List]
» 2 Member(s) | 7521 Guest(s)
