Philco 60MB cabinet restoration
#32
Thanks for the tips. I used Constatines walnut grain filler and Deft lacquer sanding sealer before the Mohawk medium brown walnut toner lacquer.
The trim sure looks like opaque black to me. Both in the remains before I stripped it and reference photos of other 60MBs. Also, the original ad describes it as black. Why would you want to see the cheap secondary plywood laminations through the toner ?
[Image: http://farm3.staticflickr.com/2835/87868...2bf2_c.jpg]
Philco 60MB cabinet restoration - by Bob Andersen - 04-06-2013, 06:57 PM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 07:46 AM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 04:26 PM
RE: Philco 60MB cabinet restoration - by Art Hoch - 04-07-2013, 05:40 PM
RE: Philco 60MB cabinet restoration - by Geoff - 04-08-2013, 11:57 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-09-2013, 10:38 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-21-2013, 11:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-04-2013, 12:48 AM
RE: Philco 60MB cabinet restoration - by Arran - 05-09-2013, 06:45 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-17-2013, 08:20 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-18-2013, 08:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-20-2013, 11:54 PM
RE: Philco 60MB cabinet restoration - by Bob Andersen - 05-22-2013, 11:15 AM
RE: Philco 60MB cabinet restoration - by jph14 - 05-22-2013, 04:46 PM
RE: Philco 60MB cabinet restoration - by EricS - 08-24-2013, 09:22 PM
Users browsing this thread: 13 Guest(s)
There are currently 10179 online users. [Complete List]
» 2 Member(s) | 10177 Guest(s)
