My vote for the worst chassis to work on (so far)
My vote is for the 41-250 chassis and its variations (41-255/280/285/287/290). Hardest Philco (IMHO) to work on; not only do you have the rubber-covered wiring headaches, but the closely spaced three section band switch with all of those rubber-coated wires going to the various sections of that switch virtually guarantees one must disassemble the switch to get to all of the wires.
I used to try and pull the rubber coating off the wires as they went into the switch assembly...until I broke a wafer in the switch assembly. Thereafter, I found it safer (for me, anyway) to disassemble the switch.
It takes a LOT of hours to redo one of these. Too many, I think.
[No subject] - by Ron Ramirez - 01-03-2008, 06:39 PM
[No subject] - by TonyJSenior - 01-03-2008, 07:30 PM
[No subject] - by BOBC - 01-04-2008, 01:58 AM
[No subject] - by Raleigh - 01-05-2008, 06:22 PM
[No subject] - by Texasrocker - 01-12-2008, 02:00 AM
[No subject] - by Bill Hutchinson - 01-30-2008, 06:58 PM
[No subject] - by Terry Judkins - 01-30-2008, 08:01 PM
[No subject] - by DeckApe - 07-23-2008, 01:19 PM
[No subject] - by Michael Dennis - 07-24-2008, 12:03 AM
[No subject] - by BDM - 07-24-2008, 10:14 AM
