Philco 15X cabinet dis-assembly
Have any of you ever restored one of these cabinets? In order to adequately apply lacquer to the control panel, columns, and sound-board, the cabinet should be disassembled. BUT so far I have not figured out how.
Suggestions?
Philco 15X cabinet dis-assembly - by TA Forbes - 05-22-2013, 07:11 PM
RE: Philco 15X cabinet dis-assembly - by Arran - 05-24-2013, 12:00 AM
There are currently 8719 online users. [Complete List]
» 2 Member(s) | 8717 Guest(s)
