Zenith...over rated or not!
I have 5 of each, and prefer the looks of the zenith cabinets.
They are much easier to work on as well.
Just depends on which model zenith you are talking about.
Some are ok, and some are very rich sounding with excellent bass.
Philco's about the same in my opinion.
Seems like most people prefer the tuning eye as well which Philco didn't do.
Just my opinion,
murf
P.S.
Ford rules!!!
Zenith...over rated or not! - by 462ron - 05-18-2013, 09:59 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-18-2013, 10:10 PM
RE: Zenith...over rated or not! - by 462ron - 05-18-2013, 10:32 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-18-2013, 10:49 PM
RE: Zenith...over rated or not! - by w4rtc - 05-18-2013, 10:55 PM
RE: Zenith...over rated or not! - by Arran - 05-18-2013, 10:57 PM
RE: Zenith...over rated or not! - by BrendaAnnD - 05-19-2013, 02:00 AM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-19-2013, 08:45 AM
RE: Zenith...over rated or not! - by w4rtc - 05-19-2013, 04:08 PM
RE: Zenith...over rated or not! - by GarySP - 05-19-2013, 04:22 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-19-2013, 04:28 PM
RE: Zenith...over rated or not! - by TA Forbes - 05-19-2013, 04:32 PM
RE: Zenith...over rated or not! - by morzh - 05-19-2013, 04:41 PM
RE: Zenith...over rated or not! - by codefox1 - 05-19-2013, 05:03 PM
RE: Zenith...over rated or not! - by Eliot Ness - 05-19-2013, 10:09 PM
RE: Zenith...over rated or not! - by Arran - 05-19-2013, 11:51 PM
RE: Zenith...over rated or not! - by BrendaAnnD - 05-20-2013, 01:48 AM
RE: Zenith...over rated or not! - by morzh - 05-20-2013, 09:31 AM
RE: Zenith...over rated or not! - by Jayce - 05-20-2013, 03:49 PM
RE: Zenith...over rated or not! - by TA Forbes - 05-20-2013, 08:23 PM
RE: Zenith...over rated or not! - by Arran - 05-21-2013, 10:51 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 05-22-2013, 07:36 AM
RE: Zenith...over rated or not! - by murf - 05-24-2013, 12:06 PM
RE: Zenith...over rated or not! - by GarySP - 05-25-2013, 09:13 PM
RE: Zenith...over rated or not! - by murf - 05-25-2013, 09:56 PM
RE: Zenith...over rated or not! - by jcr1972 - 06-01-2013, 03:55 AM
RE: Zenith...over rated or not! - by TA Forbes - 06-01-2013, 11:01 PM
RE: Zenith...over rated or not! - by Ron Ramirez - 06-01-2013, 11:15 PM
RE: Zenith...over rated or not! - by w4rtc - 06-01-2013, 11:56 PM
RE: Zenith...over rated or not! - by Eliot Ness - 06-02-2013, 01:36 PM
RE: Zenith...over rated or not! - by Art Hoch - 06-03-2013, 11:15 PM
RE: Zenith...over rated or not! - by rocketeer - 06-04-2013, 11:13 PM
There are currently 6531 online users. [Complete List]
» 2 Member(s) | 6529 Guest(s)
