Philco 38-62 cabinet restoration
#41
One trick I learned for how to deal with hairs stuck in paint or lacquer is to pick them out with a razor blade. Actually car painters use a razor blade to scrape off any runs or sags to get rid of the high spots rather then trying to completely sand them off, it's much less time consuming, you can use the same method to shave the high spot off.
RE: Philco 38-62 cabinet restoration - by Arran - 03-13-2013, 11:56 PM
RE: Philco 38-62 cabinet restoration - by Arran - 03-15-2013, 12:27 AM
RE: Philco 38-62 cabinet restoration - by Arran - 03-16-2013, 07:26 PM
RE: Philco 38-62 cabinet restoration - by Arran - 04-12-2013, 01:13 AM
RE: Philco 38-62 cabinet restoration - by Arran - 04-15-2013, 07:55 PM
RE: Philco 38-62 cabinet restoration - by Walston - 05-11-2013, 07:50 AM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 09:21 PM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 10:19 PM
RE: Philco 38-62 cabinet restoration - by Arran - 05-25-2013, 01:39 AM
There are currently 10611 online users. [Complete List]
» 2 Member(s) | 10609 Guest(s)
