When do decals go on the cabinet?
Hi guys,
I agree with Ron, placing your clear coats over the decal. Perhaps apply some early coats of clear on first, do your light sanding, levelling etc. then just before the last couple of coats apply the decal.
This way, the surface will be level across the decal, and not have much of an edge, compared to if you used clear right on top of one.
But, it's up to you.
Good luck,
Gary [Image: http://www.grabbittradios.com/radio/emoticon.gif]
When do decals go on the cabinet? - by davemc - 01-05-2008, 05:27 PM
[No subject] - by Ron Ramirez - 01-05-2008, 05:51 PM
[No subject] - by gary rabbitt - 01-06-2008, 04:34 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6805 online users. [Complete List]
» 1 Member(s) | 6804 Guest(s)
