Philco 41-603
First things first.
Try to locate (maybe Ron can give you a/the link) numerous discussion that tell you what to do to a newly acquired old radio that either has not been restored or the restoration is being questioned.
Basically, you do not power the radio until:
1. You verified that the caps (all of them preferably but as a minimum all electrolytics) have been replaced.
2. You check everything for shorts.
3. You inspected your power cord and replaced it if necessary.
4. You checked your transformer output using a Variac.
5. You checked your tubes.
6. You checked your rectifier output.
Then you can bring it up using a Variac, measure the voltages...etc.
Philco 41-603 - by philco22 - 05-25-2013, 09:19 PM
RE: Philco 41-630 - by Ron Ramirez - 05-25-2013, 09:47 PM
RE: Philco 41-630 - by morzh - 05-25-2013, 09:54 PM
RE: Philco 41-630 - by Ron Ramirez - 05-25-2013, 10:30 PM
RE: Philco 41-630 - by morzh - 05-25-2013, 10:38 PM
RE: Philco 41-630 - by philco22 - 05-26-2013, 12:12 PM
RE: Philco 41-603 - by philco22 - 05-31-2013, 06:34 PM
RE: Philco 41-603 - by morzh - 05-31-2013, 07:58 PM
RE: Philco 41-603 - by morzh - 05-25-2013, 09:37 PM
91H Code 126 Restore
Philco 70 antenna lead
