Help with installing a new electrolytic part
Could I drill a small hole that goes through the can and solder the neg side of the electrolytic to the can that way. I would do it in a place where the cardboard sleeve covers the can. I am looking for the most authentic way so when you look at the can you will not be able to tell.
Here is where the positive lead come out of the can, it is the center screw coming out of each can. The neg side of the original electrolytic must of touched somewhere inside the can.
Philco repair bench shows a way to re-stuff a mershon cap, I not this is not the case for me, but I could do something just as similar. Let me know if this is feasible.
Thanks
Jon
RE: Help with installing a new electrolytic part - by Philco281989 - 05-26-2013, 04:28 PM
91H Code 126 Restore
