Philco 620 bakelite block
David:
The caps actually are more in a series configuration inside those blocks with the common connection of them getting connected to the chassis. You take one leg from each of the two caps and connect to the bakelight lug (wire) that ultimately connects to the chassis via the mounting hardware. The remaining ends of the caps each go to their own respective lugs (wires). Hope that helps.
Tony
Philco 620 bakelite block - by David B - 01-07-2008, 06:44 PM
[No subject] - by PhilcoPhil - 01-07-2008, 06:53 PM
Philco 620, bakelite blocks - by David B - 01-07-2008, 09:47 PM
[No subject] - by TonyJSenior - 01-08-2008, 07:39 AM
[No subject] - by 49Stude63 - 01-10-2008, 05:25 PM
Philco 620 - by David B - 01-10-2008, 07:47 PM
[No subject] - by 49Stude63 - 01-10-2008, 10:03 PM
[No subject] - by Texasrocker - 01-11-2008, 12:13 AM
[No subject] - by Ron Ramirez - 01-11-2008, 08:05 AM
Keep those blocks! - by AI2V - 01-11-2008, 11:07 AM
[No subject] - by Chris Drumma - 01-11-2008, 04:01 PM
[No subject] - by 49Stude63 - 01-11-2008, 04:03 PM
Bakelite Blocks - by David B - 01-11-2008, 08:38 PM
[No subject] - by 49Stude63 - 01-11-2008, 11:43 PM
Philco 620 - by David B - 01-12-2008, 12:50 AM
[No subject] - by Texasrocker - 01-12-2008, 01:47 AM
Philco 620 - by David B - 01-12-2008, 08:40 AM
Re: Philco 620 - by Ron Ramirez - 01-12-2008, 11:28 AM
[No subject] - by 49Stude63 - 01-12-2008, 01:16 PM
Philos 620 - by David B - 01-12-2008, 07:15 PM
[No subject] - by gary rabbitt - 01-17-2008, 04:46 AM
There are currently 10945 online users. [Complete List]
» 2 Member(s) | 10943 Guest(s)
