Philco Model 20
Well, yes, 630 Volt non-polarized of the correct value.
Keep in mind that, as I said in the thread above, most of the resistors are going to be bad as well. With the type used in that radio, they don't just drift off, they go open.
Philco Model 20 - by pete7189 - 05-16-2013, 12:34 AM
RE: Philco Model 20 - by codefox1 - 05-16-2013, 01:13 PM
RE: Philco Model 20 - by GarySP - 05-16-2013, 06:39 PM
RE: Philco Model 20 - by Arran - 05-16-2013, 07:26 PM
RE: Philco Model 20 - by GarySP - 05-16-2013, 09:58 PM
RE: Philco Model 20 - by gary rabbitt - 05-16-2013, 11:34 PM
RE: Philco Model 20 - by Arran - 05-17-2013, 03:03 AM
RE: Philco Model 20 - by pete7189 - 05-17-2013, 07:20 AM
RE: Philco Model 20 - by Mondial - 05-17-2013, 02:15 PM
RE: Philco Model 20 - by pete7189 - 05-19-2013, 11:55 PM
RE: Philco Model 20 - by Arran - 05-20-2013, 01:00 AM
RE: Philco Model 20 - by pete7189 - 05-20-2013, 03:07 AM
RE: Philco Model 20 - by GarySP - 05-20-2013, 11:03 AM
RE: Philco Model 20 - by pete7189 - 05-24-2013, 02:57 AM
RE: Philco Model 20 - by 7estatdef - 05-26-2013, 08:05 AM
RE: Philco Model 20 - by Phlogiston - 05-26-2013, 09:48 AM
RE: Philco Model 20 - by pete7189 - 05-26-2013, 06:52 PM
RE: Philco Model 20 - by Phlogiston - 05-26-2013, 07:40 PM
RE: Philco Model 20 - by morzh - 05-26-2013, 08:05 PM
RE: Philco Model 20 - by pete7189 - 05-27-2013, 01:11 AM
RE: Philco Model 20 - by Phlogiston - 05-27-2013, 09:34 AM
RE: Philco Model 20 - by morzh - 05-27-2013, 11:24 AM
RE: Philco Model 20 - by GarySP - 05-27-2013, 07:24 PM
RE: Philco Model 20 - by morzh - 05-27-2013, 08:01 PM
RE: Philco Model 20 - by pete7189 - 05-28-2013, 06:27 AM
RE: Philco Model 20 - by 7estatdef - 05-28-2013, 07:25 AM
RE: Philco Model 20 - by klondike98 - 05-28-2013, 09:30 AM
RE: Philco Model 20 - by morzh - 05-28-2013, 11:08 AM
RE: Philco Model 20 - by klondike98 - 05-28-2013, 02:09 PM
RE: Philco Model 20 - by pete7189 - 06-01-2013, 02:06 AM
RE: Philco Model 20 - by morzh - 06-01-2013, 11:35 AM
RE: Philco Model 20 - by GarySP - 06-02-2013, 04:22 PM
RE: Philco Model 20 - by pete7189 - 06-04-2013, 10:43 PM
RE: Philco Model 20 - by morzh - 06-04-2013, 10:46 PM
RE: Philco Model 20 - by pete7189 - 06-05-2013, 12:08 AM
RE: Philco Model 20 - by GarySP - 06-05-2013, 12:34 PM
RE: Philco Model 20 - by pete7189 - 06-06-2013, 04:25 AM
RE: Philco Model 20 - by GarySP - 06-06-2013, 12:24 PM
RE: Philco Model 20 - by pete7189 - 06-26-2013, 10:53 PM
RE: Philco Model 20 - by morzh - 06-26-2013, 11:11 PM
RE: Philco Model 20 - by pete7189 - 06-26-2013, 11:18 PM
RE: Philco Model 20 - by morzh - 06-27-2013, 01:36 PM
RE: Philco Model 20 - by pete7591 - 09-12-2014, 02:07 AM
RE: Philco Model 20 - by morzh - 09-12-2014, 10:15 AM
RE: Philco Model 20 - by radiohenry - 09-12-2014, 03:53 PM
