Help with installing a new electrolytic part
I have never made perfect cuts when cutting a can apart (I use a dremel with a cutoff wheel). I use to make an index mark so I could align the two parts. Now I just take them to a bench disk sander and "true" both parts. The cardboard tube holds the two halves together quite nicely along with the clamp.
Jerry
RE: Help with installing a new electrolytic part - by jerryhawthorne - 05-27-2013, 03:33 PM
91H Code 126 Restore
