37-650 or not?
Hi Gary
That cabinet was available with Models 37-643, 37-650, 37-660, 37-665 and 37-2650 chassis.
The 37-643, 37-660 and 37-665 used a different escutcheon with larger dial opening. You will note that the dial opening on the 37-650 is smaller, but the escutcheon itself is the same size.
37-650 or not? - by n9vu - 01-11-2008, 01:13 AM
[No subject] - by Ron Ramirez - 01-11-2008, 08:11 AM
[No subject] - by n9vu - 01-11-2008, 09:49 AM
[No subject] - by n9vu - 01-15-2008, 07:46 AM
[No subject] - by Ron Ramirez - 01-15-2008, 08:22 AM
[No subject] - by planigan - 03-02-2008, 01:57 AM
[No subject] - by Ron Ramirez - 03-02-2008, 09:38 AM
Philco 91 Tuning Condenser
There are currently 8249 online users. [Complete List]
» 3 Member(s) | 8246 Guest(s)
