Philco 620 bakelite block
TexasRocker,
One of the things I like about Philcos is the bakelite blocks. I do restuff all my blocks and enjoy doing it. I do it like AI2V suggested. To each his own I guess. I do see your point about space though.
I would gladly take any blocks you have off your hands also! Ron save some for me!
Chris
Philco 620 bakelite block - by David B - 01-07-2008, 06:44 PM
[No subject] - by PhilcoPhil - 01-07-2008, 06:53 PM
Philco 620, bakelite blocks - by David B - 01-07-2008, 09:47 PM
[No subject] - by TonyJSenior - 01-08-2008, 07:39 AM
[No subject] - by 49Stude63 - 01-10-2008, 05:25 PM
Philco 620 - by David B - 01-10-2008, 07:47 PM
[No subject] - by 49Stude63 - 01-10-2008, 10:03 PM
[No subject] - by Texasrocker - 01-11-2008, 12:13 AM
[No subject] - by Ron Ramirez - 01-11-2008, 08:05 AM
Keep those blocks! - by AI2V - 01-11-2008, 11:07 AM
[No subject] - by Chris Drumma - 01-11-2008, 04:01 PM
[No subject] - by 49Stude63 - 01-11-2008, 04:03 PM
Bakelite Blocks - by David B - 01-11-2008, 08:38 PM
[No subject] - by 49Stude63 - 01-11-2008, 11:43 PM
Philco 620 - by David B - 01-12-2008, 12:50 AM
[No subject] - by Texasrocker - 01-12-2008, 01:47 AM
Philco 620 - by David B - 01-12-2008, 08:40 AM
Re: Philco 620 - by Ron Ramirez - 01-12-2008, 11:28 AM
[No subject] - by 49Stude63 - 01-12-2008, 01:16 PM
Philos 620 - by David B - 01-12-2008, 07:15 PM
[No subject] - by gary rabbitt - 01-17-2008, 04:46 AM
There are currently 3777 online users. [Complete List]
» 1 Member(s) | 3776 Guest(s)
