80 Jr Question
I don't see any evidence of the small glue blocks but the more I look at the actual base of the cabinet it looks like that might have been a replacement piece of plywood as well. The chassis mounting holes were drilled and then a second set redrilled at a slightly offset position from the first.
80 Jr Question - by klondike98 - 05-28-2013, 07:32 PM
RE: 80 Jr Question - by Mondial - 05-28-2013, 07:58 PM
RE: 80 Jr Question - by klondike98 - 05-28-2013, 08:17 PM
RE: 80 Jr Question - by Art Hoch - 05-28-2013, 08:28 PM
RE: 80 Jr Question - by klondike98 - 05-28-2013, 08:46 PM
RE: 80 Jr Question - by Mondial - 05-28-2013, 09:11 PM
RE: 80 Jr Question - by klondike98 - 05-28-2013, 09:29 PM
RE: 80 Jr Question - by Mondial - 05-28-2013, 10:14 PM
RE: 80 Jr Question - by klondike98 - 05-29-2013, 12:27 PM
There are currently 9958 online users. [Complete List]
» 2 Member(s) | 9956 Guest(s)
