How to deal with blush
Well, I should have known it was too humid to spray finish coat lacquer on today and now I have some blush to take care of. It's on the final step after I toned the "cheap" wood with Mohawk toner to darken it. What do you say I should do now? I don't want to have to sand and then retone several small areas including the grille bars on my Philco 38-1 console.
How to deal with blush - by Art Hoch - 05-29-2013, 01:59 PM
RE: How to deal with blush - by Phlogiston - 05-29-2013, 02:05 PM
RE: How to deal with blush - by Art Hoch - 05-29-2013, 04:03 PM
RE: How to deal with blush - by Ron Ramirez - 05-29-2013, 06:46 PM
RE: How to deal with blush - by TA Forbes - 05-29-2013, 06:50 PM
There are currently 8520 online users. [Complete List]
» 1 Member(s) | 8519 Guest(s)
