Restoring my 37-116. It plays now!
Threads: 92
City: Clayton, NC
My bad with respect to the 6J5/6J5GT issue. This pertains to the Philco sets that had the shield base that fit very closely around the circumference of the bakelite tube base.
RE: Starting on my 37-116 - by TA Forbes - 05-29-2013, 06:48 PM
Users browsing this thread: 39 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10003 online users. [Complete List] » 1 Member(s) | 10002 Guest(s)
