  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
#70
Many Scotts came with Jensen tweeters, so it's OK.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by TA Forbes - 05-29-2013, 06:57 PM
