41-608 phono question
The 41-611P that I have has the BOM arm but is missing the swivel mount, so if anyone has an extra swivel mount let me know the cost. I have a friend that does a lot of intricate machining work so he told me to pull one of the pivots and he would make copies for me. If they work I will see what he will charge for them, they may look non-original but who is going to crawl under the cabinet to check them out. The one I have is the 3 poster unit, very nice radio the Ron is trying to talk me out of.
41-608 phono question - by Guest - 10-27-2005, 08:23 PM
[No subject] - by Ron Ramirez - 10-29-2005, 03:17 PM
Philco changer for 1941 - by Doug Houston - 11-10-2005, 05:41 PM
[No subject] - by Ron Ramirez - 11-11-2005, 12:34 AM
[No subject] - by Guest - 11-16-2005, 10:25 PM
[No subject] - by 49Stude63 - 11-16-2005, 10:37 PM
[No subject] - by Ron Ramirez - 11-16-2005, 11:30 PM
