Philco 41-603
I have started to replace the caps and the old electrolytic cap is 20 mfd. It has a red positive at one end and a black negative and a yellow positive at the other end. I have a new cap
that is 22 uf with 450 volts that has one positive wire and one negative wire. I know that the
new cap negative has to go to the negative on the radio. how do I wire the two positive
wires ?
Tim
Philco 41-603 - by philco22 - 05-25-2013, 09:19 PM
RE: Philco 41-630 - by Ron Ramirez - 05-25-2013, 09:47 PM
RE: Philco 41-630 - by morzh - 05-25-2013, 09:54 PM
RE: Philco 41-630 - by Ron Ramirez - 05-25-2013, 10:30 PM
RE: Philco 41-630 - by morzh - 05-25-2013, 10:38 PM
RE: Philco 41-630 - by philco22 - 05-26-2013, 12:12 PM
RE: Philco 41-603 - by philco22 - 05-31-2013, 06:34 PM
RE: Philco 41-603 - by morzh - 05-31-2013, 07:58 PM
RE: Philco 41-603 - by morzh - 05-25-2013, 09:37 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6663 online users. [Complete List]
» 1 Member(s) | 6662 Guest(s)
