Philco 41-603
You cannot wire it just like that. One is a dual cap and the other is a single with negative not directly connected to the can. You need two of those to replace one of the original.
Philco 41-603 - by philco22 - 05-25-2013, 09:19 PM
RE: Philco 41-630 - by Ron Ramirez - 05-25-2013, 09:47 PM
RE: Philco 41-630 - by morzh - 05-25-2013, 09:54 PM
RE: Philco 41-630 - by Ron Ramirez - 05-25-2013, 10:30 PM
RE: Philco 41-630 - by morzh - 05-25-2013, 10:38 PM
RE: Philco 41-630 - by philco22 - 05-26-2013, 12:12 PM
RE: Philco 41-603 - by philco22 - 05-31-2013, 06:34 PM
RE: Philco 41-603 - by morzh - 05-31-2013, 07:58 PM
RE: Philco 41-603 - by morzh - 05-25-2013, 09:37 PM
The speaker table error?
Philco 70 antenna lead
