Veneer repair and finish advice for Philco 14MX
As for reproducing the fluted molding, I don't think that using a drill to reproduce it will be too successful. If you look at the radius of each flute it makes up maybe 1/3 of a circle, so to reproduce that with a drill means that each hole would overlap, so at the very least you would need a thicker board. It also looks like each flute is parallel to the grain, and quite frankly it's a real pain trying to drill a perfectly straight old through the endgrain of a board. My guess is that by cutting the flutes parallel to the grain they could avoid the cutter, likely a shaper or some sort of molding head cutter, tearing the grain out, it also makes a cleaner cut as opposed to going across the grain.
What they likely did to make this molding is they ran an entire board through a machine, similar to a thickness planer, to cut the profile, maybe 8 or 10 inches wide, then they cut that board across the grain into 1-1/2 inch strips as needed for the set. If someone wanted to reproduce it likely a router and a jig would be the simplest and least dangerous method, or a molding head cutter in a tablesaw, which is a lot more dangerous.
RE: Veneer repair and finish advice for Philco 14MX - by Arran - 05-31-2013, 09:45 PM
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
