Philco 37-116 Auto Tuning
Just an update on the grommets. I found a link on Philco Repair Bench to Ed's Radio and found all the grommets I need.
http://www.renovatedradios.com/parts.html
Don
Philco 37-116 Auto Tuning - by Guest - 01-12-2008, 04:31 PM
[No subject] - by Guest - 01-13-2008, 01:15 AM
[No subject] - by Guest - 01-13-2008, 01:49 AM
[No subject] - by 49Stude63 - 01-13-2008, 09:06 AM
There are currently 11048 online users. [Complete List]
» 2 Member(s) | 11046 Guest(s)
