Philco 118MX scored
I spent some time last night going over the radio in more detail.
Here's what I found when I removed the back. I think the cloth was originally glued to the fiberboard but it's completely separated now.
[Image: http://farm4.staticflickr.com/3795/89095...291d_c.jpg]
Is that speaker installed upside down ? I would have expected the dust screen to be on top.
[Image: http://farm8.staticflickr.com/7457/89089...2100_c.jpg]
The speaker wires have seen better days, but the ac power cord is in good condition considering it's age.
[Image: http://farm6.staticflickr.com/5339/89089...e57d_c.jpg]
If I'm understanding this notice correctly, the screws holding the chassis down should have been removed way back when it was purchased. It took some force to pry the hardened rubber chassis mounts away from the plywood.
[Image: http://farm6.staticflickr.com/5324/89089...3e7e_c.jpg]
Finally, a look at the chassis. Looks pretty good from the top. No signs of corrosion.
[Image: http://farm4.staticflickr.com/3689/89089...b6e5_c.jpg]
I found some evidence of repairs underneath like some Solar "sealdtite" capacitors. The bandswitch is frozen but the other controls seems to operator correctly.
[Image: http://farm8.staticflickr.com/7431/89089...fe3d_b.jpg]
I'm not sure the the power/volume control is original. I was a little surprised to see that four section electrolytic. I expected a non-opolarized tar block cap for values that small.
[Image: http://farm4.staticflickr.com/3684/89089...c9ed_c.jpg]
The dial scale is filthy and uniformly warped back around the edge. I think that might be how it was made though ?
[Image: http://farm3.staticflickr.com/2815/89095...c094_c.jpg]
Philco 118MX scored - by Bob Andersen - 05-30-2013, 09:51 PM
RE: Philco 118MX scored - by morzh - 05-30-2013, 10:57 PM
RE: Philco 118MX scored - by Ron Ramirez - 05-31-2013, 10:16 AM
RE: Philco 118MX scored - by w4rtc - 05-31-2013, 01:50 PM
RE: Philco 118MX scored - by Bob Andersen - 05-31-2013, 04:05 PM
RE: Philco 118MX scored - by morzh - 05-31-2013, 04:18 PM
RE: Philco 118MX scored - by Arran - 05-31-2013, 06:21 PM
RE: Philco 118MX scored - by 7estatdef - 05-31-2013, 08:55 PM
RE: Philco 118MX scored - by Bob Andersen - 06-01-2013, 09:37 PM
RE: Philco 118MX scored - by morzh - 06-01-2013, 09:59 PM
RE: Philco 118MX scored - by Philco281989 - 06-01-2013, 10:02 PM
RE: Philco 118MX scored - by morzh - 06-01-2013, 10:04 PM
RE: Philco 118MX scored - by Bob Andersen - 06-01-2013, 10:31 PM
RE: Philco 118MX scored - by TA Forbes - 06-01-2013, 10:43 PM
RE: Philco 118MX scored - by Groundhog74 - 06-06-2013, 07:38 AM
Philco 91 Tuning Condenser
There are currently 2831 online users. [Complete List]
» 1 Member(s) | 2830 Guest(s)
