Philco 118MX scored
Bob, I am pretty sure the dial scale is suppose to be slightly tapered back to prevent rubbing on the inside of the cabinet, my Philco 144, which is a 1934 model, and model 71B from 1932 both have the same warped back look.
Jon
Philco 118MX scored - by Bob Andersen - 05-30-2013, 09:51 PM
RE: Philco 118MX scored - by morzh - 05-30-2013, 10:57 PM
RE: Philco 118MX scored - by Ron Ramirez - 05-31-2013, 10:16 AM
RE: Philco 118MX scored - by w4rtc - 05-31-2013, 01:50 PM
RE: Philco 118MX scored - by Bob Andersen - 05-31-2013, 04:05 PM
RE: Philco 118MX scored - by morzh - 05-31-2013, 04:18 PM
RE: Philco 118MX scored - by Arran - 05-31-2013, 06:21 PM
RE: Philco 118MX scored - by 7estatdef - 05-31-2013, 08:55 PM
RE: Philco 118MX scored - by Bob Andersen - 06-01-2013, 09:37 PM
RE: Philco 118MX scored - by morzh - 06-01-2013, 09:59 PM
RE: Philco 118MX scored - by Philco281989 - 06-01-2013, 10:02 PM
RE: Philco 118MX scored - by morzh - 06-01-2013, 10:04 PM
RE: Philco 118MX scored - by Bob Andersen - 06-01-2013, 10:31 PM
RE: Philco 118MX scored - by TA Forbes - 06-01-2013, 10:43 PM
RE: Philco 118MX scored - by Groundhog74 - 06-06-2013, 07:38 AM
Philco 91 Tuning Condenser
There are currently 5827 online users. [Complete List]
» 3 Member(s) | 5824 Guest(s)
